RG-ES05G
Switch Seri Plastik Ruijie Reyee merupakan switch desktop yang disesuaikan untuk perusahaan kecil, pengawasan skala-kecil dan SOHO, yang totalnya terdiri dari 4 model berbeda untuk memenuhi kebutuhan jaringan pelanggan perusahaan kecil. Switch ini memiliki fitur plug and play, nol konfigurasi dan kesesuaian dengan berbagai terminal seperti kamera jaringan, mesin cetak, PC, dll., untuk menawarkan pengalaman pemasangan cepat.
Exquisite Design
The matte-finish diamond pattern design with honeycomb heat dissipation holes at the bottom ensures effective heat dissipation while offering an exquisite appearance. The embedded foot pads and hidden hanging hole design also provide ease of use for the users.
Enterprise-grade Quality
The high-quality 8-core network cable and enterprise-grade components ensure no packet loss or lagging for data transmission.
Rigorous Testing
Plug and Play & Energy Saving
Self-adaptive feature is supported for the network ports. With zero configuration, the device can operate instantly after plugging in. The energy saving feature enables the non-operating ports to automatically reduce power consumption, and the fanless design also enables noiseless operation.
The series is an ideal choice for surveillance, small enterprises, school dormitories, SOHO, and domestic use.
RG- ES05G |
5 10/100/1000M Base-T ports |
RG- ES08G |
8 10/100/1000M Base-T ports |
- Installation Guide
- RG-ES05G, ES08G Buku Panduan (V1.0) 2023-10-23
- Implementation Cookbook
- Tanya-Jawab
- Pertanyaan Umum Switch Seri Reyee (V1.0) 2023-04-28
